1984 240 Turbo Wagon
FEATURES
Safety
Four three-point inertia reel seat belts, one lap belt for rear-center passenger.
Interior
Air Conditioner.
Adjustable front bucket seats.
Adjustable lumbar support on front seats
Leather Upholstery
Centrally controlled door locking system including tailgate or trunk
Interior light delay(on opening or closing one of the doors)
Rear center armrest
Warning buzzer for headlights, key, and safety belts.
Full interior carpeting, including trunk/cargo area.
Illuminated, lockable glove box with vanity mirror.
Cargo compartment light.
Cargo tie-down rings.
Lockable storage compartment beneath the cargo area floor.
Rear center armrest.
Power windows.
Heated driver's seat.
Engine Compartment light.
Instruments: 120 mph speedometer, odometer, trip odometer, quartz crystal clock, fuel gauge, temperature gauge, tachometer, oil pressure gauge.
Turbo boost gauge.
Voltmeter.
Exterior
Tinted windows, with dark tint band along the top of the windshield.
Dual power mirrors
Electric rear window defroster with timer, Integral front side window defoggers
Windshield wipers with intermittent cycle
Halogen high and low beam headlights
Front spoiler
Rear window wiper/washer with intermittent feature
Alloy wheels
Engine
Fuel injection in-line four-cylinder, B21FT-LH engine with cast iron block, light alloy "cross-flow" cylinder head, overhead camshaft, Lambda SondÃÂ
emission control, exhaust-driven turbo-compressor.
Horsepower, SAE net:131 @ 5400
Torque, ft./lbs., SAE net:155 @ 3750 rpm
Compression Ratio 7.5:1
Fuel Capacity 15.8 gals
Transmission
Manual: fully synchronized four-speed with electrically operated overdrive. Rear axle ratio 3.73:1
Automatic four-speed with overdrive fourth gear: floor-mounted-shift lever. Rear axle ratio:3.91:1(OPTION)
Suspension
McPherson struts incorporating coil springs and telescopic shock absorbers. Stabilizer bar.
Rear suspension includes a rigid, live rear axle located by longitudinal control arms and torque rods. Lateral location by track rod. Coil springs and telescopic shock absorbers. Stabilizer bar.
Tires
Low rolling resistance, steel-belted radial tires. 195/60R15
Steering
Power-assisted rack and pinion gear, 32'2" turning circle, 3.5 turns lock to lock.
Brakes
Power-assisted four-wheel disc brakes. Self-adjusting four-wheel disc brakes, tandem-type power-assistance. Each circuit of the dual triangular split hydraulic brake system connects both front wheels and one real wheel. Stepped-bore master cylinder maintains nearly normal pedal effort if one circuit fails. Hand brake operates mechanically on separate rear wheel drums.
Dimensions and Weights
Wheelbase 104.3 in.
Overall Length 188.8 in.
Overall Width 67.3 in.
Overall Height 57.5 in.
Front Track 56.3 in.
Rear Track 53.5 in.
Front Headroom 37.4 in.
Rear Headroom 36.6 in.
Front Legroom 39.8 in.
Rear Legroom 36.6 in.
Cargo Capacity Seat Up 41.1 cu ft.
Cargo Capacity Seat Down 76.0 cu ft.
Towing Capacity 3300 lbs.
Curb Weight 3144 lbs.
Exterior & Upholstery Colors
Exterior Colors Black, Red, White, Silver Metallic, Graphite Metallic, Blue Metallic, Sienna Brown Metallic
Upholstery Colors Blue, Black, Beige
